So what happend?
Guzzidiag has been used thousands of times to write mappings to 5am ecu's.
It has a repair mode if it fails, what can happen if you forget that the laptop needs power or shuts down during writing. Or like someone who tried to write a map with battery at 7 volt.
When communication is good, the bike and laptop are stable nothing goes wrong. Since a year the Aprilia rsv4 and Tuono v4 can be mapped too, that also has been proven stable.
First make a backup of you map, not that I don't have it, but because you test that way if the laptop is good to communicate with the bike.
I still read here fear to touch mapping, and zero knowledge about what happens inside the ecu. Educate yourself, it's good to know what happens inside.
For the ones who read German, the German guzziforum has a lot of explanation about what happens inside
https://www.guzzi-forum.de/Forum/index.php?board=74.0And no, I was not the one who made Guzzidiag, but I was the one who had the idea to get it developed, and found a genius who could.
